Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Hyote
Post
by Hyote » 16 May 2024, 14:26
Coldplayer wrote: ↑16 May 2024, 03:25
delete SmoothMouseXCurve and SmoothMouseYCurve in Computer\HKEY_CURRENT_USER\Control Panel\Mouse, MouseSpeed 0 ; MouseHoverTime 0 ; new String value: MouseAccel ; MouseAccel_Max ; MouseAccel_Scale all of them to 0
Can you screenshot what this should look like?
Instead of deleting SmoothMouseX and Y I now recommend changing their values to 0. Here is a pic of my regedit.
- Untitled.png (16.21 KiB) Viewed 4942 times
joolae
Post
by joolae » 19 May 2024, 00:50
Here's mine for mouse: accel @0 , no accel max/scale, hover time at 10, and I highly suggest to try mouse speed at "-".
- regedit_9St39PF8Wb.png (19.77 KiB) Viewed 4694 times
dizelcs
Post
by dizelcs » 03 Jun 2024, 06:43
Slender wrote: ↑15 May 2024, 20:03
install LTSC w10 21h2 with Revi-Config via ventoy usb installation.
Is ventoy superior to rufus, besides the multiple iso's on 1 usb?
Post
by Slender » 04 Jun 2024, 07:02
dizelcs wrote: ↑03 Jun 2024, 06:43
when you do what I wrote, you will understand
kenj12345
Post
by kenj12345 » 04 Jun 2024, 07:27
Slender wrote: ↑04 Jun 2024, 07:02
excuse me, but can I go into more detail, is revi-config revios?21 h2 ltsc does faceit work?
dizelcs
Post
by dizelcs » 04 Jun 2024, 17:14
I'm also using Revi config, but winver 22h2 and installed with rufus.
I will try ventoy method for weekend. Thanks.
Post
by Slender » 04 Jun 2024, 17:26
kenj12345 wrote: ↑04 Jun 2024, 07:27
i dont know i dont use tpm
