Steam shader pre caching [CS2]
The90sPope
Re: Steam shader pre caching [CS2]
Post by The90sPope » 24 Jul 2024, 17:04
Riggedinho wrote:
23 Jul 2024, 22:19
Hi JimCarry
Yes shader disabled indeed I made an error of assessment.
As for launch options, I personally use none.
And then a lot of people have already said that putting launch options could be counterproductive. Back in the days of CS:GO a developer said he didn't recommend using the -high command.
As for the command you wrote I don't even dare to change anything as my game is perfect :D
Agreed.
No launch options. Do your scheduling right on those duo chiplet AMD x3Ds and you're good.
Game keeps being updated, keep it stock. Trust me, the extra options you add either don't work or harm in the most cases.
“Death is a funny thing. Not funny haha, like a Woody Allen movie, but funny strange, like a Woody Allen marriage.”
― Norm Macdonald, Based on a True Story
JimCarry
Post by JimCarry » 25 Jul 2024, 20:40
The90sPope wrote:
24 Jul 2024, 17:04
Riggedinho wrote:
23 Jul 2024, 22:19
Hi JimCarry
Agreed.
In cs go yes in cs2 no,when you in game type in console sys_info and look for "Engine thread pool:"
In my case i5 6600 it was Engine thread pool: 3 thread(s),after launch option "-threads 5" when i go in game and check sys_info it says: "Engine thread pool: 4 thread(s)" ,do benchmark and compare i show this to at least 3 people everyone did benchmark before and after, all of themdid have 20 or 30 % increase in fps,check it,it will not cost you anything if dont like it delete the launch option.
The90sPope
Post by The90sPope » 26 Jul 2024, 14:06
JimCarry wrote:
25 Jul 2024, 20:40
The90sPope wrote:
24 Jul 2024, 17:04
Riggedinho wrote:
23 Jul 2024, 22:19
Hi JimCarry
Agreed.
Yes, I've seen people on X claiming it did boost FPS in some cases. But none of them did end-to-end latency test, so I can't recommend it. If someone brings that test in addition as proof, I am happy to stand corrected. I have tried it on my 5800X3D with no benefit.
JimCarry
Post by JimCarry » 26 Jul 2024, 16:46
The90sPope wrote:
26 Jul 2024, 14:06
JimCarry wrote:
25 Jul 2024, 20:40
The90sPope wrote:
24 Jul 2024, 17:04
Riggedinho wrote:
23 Jul 2024, 22:19
Hi JimCarry
Agreed.
Ok,but in your case the i think it must be -threads 17 did you try it like that ?
The90sPope
Post by The90sPope » 27 Jul 2024, 14:06
JimCarry wrote:
26 Jul 2024, 16:46
The90sPope wrote:
26 Jul 2024, 14:06
JimCarry wrote:
25 Jul 2024, 20:40
The90sPope wrote:
24 Jul 2024, 17:04
Agreed.
By default 5800X3D gets 7 threads to run the game, with no launch options, I tried running on 8 threads and on all 16 threads. The results are almost the same, marginal differences.
All in all I get slightly better lows and avg FPS with no launch options. It's marginal, but there.
If you wanna get even better lows you disable SMT.
I cannot recommend running this games on all CPUs, It does not make sense. You need free CPUs for other stuff.
If you own a 5800X3D, leave it default and disable SMT to boost lows a bit. End of story for this CPU.
FPSHeaven guy on X is running his tests with capped FPS, which I would never do to benchmark anything like that, so he might get weird results. This shit is getting spread around on X fast, but people don't test for themselves and blindly adopt the settings.
