useplatformclock (Windows stutters)
LaggyTyp
Re: useplatformclock (Windows stutters)
bcdedit /set useplatformclock false
bcdedit /set useplatformtick yes
bcdedit /set tscsyncpolicy legacy
bcdedit /set disabledynamictick no
- Slender
you not need any of that settings.
windows 11 uses RTC-tick by default.
for me, use disabledynamicktick in w11 cause problems with kernel timer (it stuck 983 us, without 0-3). same with useplatformtick yes.
w11 not need any bcdedit
upd: ahh, you set NO for DDT, i will try it.
BH_231
Mine stays at 1005us to 1503us when a game or web browser is opened, when nothing else is running it goes from 14-500usSlender wrote: ↑11 Apr 2024, 14:54you not need any of that settings.
games call for a 1ms timer, but i have it set to .5034 like you recommended, is it possible the game is overriding the custom timer ive set?
- Slender
i have 497us per game w11BH_231 wrote: ↑30 Aug 2024, 16:41Mine stays at 1005us to 1503us when a game or web browser is opened, when nothing else is running it goes from 14-500usSlender wrote: ↑11 Apr 2024, 14:54you not need any of that settings.
Gadzzaa
Sorry for reviving the post. I got some interesting feedback.
12600k - 5.1Ghz + 3900Mhz Ram and a gigabyte Z690 UD DDR4 motherboard
All tests are done in TimerBench1.5 and Windows 11 24H2
HPET is enabled in BIOS:
bcdedit /deletevalue useplatformclock > 10Mhz (Invariant TSC)
bcdedit /set useplatformclock true > 19.20Mhz (HPET)
Disabling HPET in BIOS + bcdedit/set useplatformclock true > 3.58Mhz (Unknown)
Haven't tested any games yet but will update this post if i come into any issues.
- Slender
when you use useplatformclock with hard disable hpet you get ACPI PMT Timer with stable 3.58Mhz.Gadzzaa wrote: ↑23 Nov 2024, 10:07Sorry for reviving the post. I got some interesting feedback.
you dont need use any bcdedit in w11.
(only globaltimerres reg + set 0.5033 (or 0.5034) timer)
Gadzzaa
Would ACPI PMT Timer not be better than Invariant TSC since it has a lower Mhz?Slender wrote: ↑23 Nov 2024, 15:34when you use useplatformclock with hard disable hpet you get ACPI PMT Timer with stable 3.58Mhz.Gadzzaa wrote: ↑23 Nov 2024, 10:07Sorry for reviving the post. I got some interesting feedback.
- Slender
i feel it more smooth but bad responce vs tsc.Gadzzaa wrote: ↑24 Nov 2024, 11:20Would ACPI PMT Timer not be better than Invariant TSC since it has a lower Mhz?Slender wrote: ↑23 Nov 2024, 15:34when you use useplatformclock with hard disable hpet you get ACPI PMT Timer with stable 3.58Mhz.Gadzzaa wrote: ↑23 Nov 2024, 10:07Sorry for reviving the post. I got some interesting feedback.
i remember im use it in 2020 for cod mw19, it feel better then new w10 tsc.
test it and write about your feel.
- imprecise
That is the only change I make to the setting, without touching BIOS. There is a noticeable difference in both w10 and w11. I'm not claiming this is the best setting, but it is an improvement over default.
2023 Esports Guide: forums.blurbusters.com/viewtopic.php?t=11799
Windows 10 Esports Guide: forums.blurbusters.com/viewtopic.php?t=10724
- Slender
that make screen more smooth but mouse is bad controllable.
in w11 ddt yes cause big desync for me (i think because w11 uses RTC tick)
