Thanks, does it matter to use hybrid or true fibre for purpose of lowest latency?paddyhhh wrote: β16 Jul 2025, 07:30Grasshopper85 wrote: β15 Jul 2025, 09:56https://www.amazon.com.au/GeoHN-G-Certi ... rce=1&th=1
Does anyone know if this is a true fibre optic hdmi 2.1 cable, or is it hybrid?
Hybrid.
True fiber have own power supply as this cable
https://amzn.eu/d/fV6T1LS
Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Grasshopper85
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Sandy
OMG! I changed to a HDMI cable with a shielded ferrite and now the input lag is gone. I've had this input lag problem for 10 years.
Grasshopper85
MontyTheAverage
pervysage19
Oh wow, these are cool. I did not know these existed.paddyhhh wrote: β16 Jul 2025, 07:30Grasshopper85 wrote: β15 Jul 2025, 09:56https://www.amazon.com.au/GeoHN-G-Certi ... rce=1&th=1
Hybrid.
Would be useful to connect my big screen TV in the other room to my gaming PC but without creating an electrical link between the two.
I wonder, do these "pure" fiber cables exist for DisplayPort as well or only HDMI?
- Slender
- Slender
do your vga support hdmi 2.1?Grasshopper85 wrote: β15 Jul 2025, 00:49I would like to use hdmi2.1 though because I have the zowie xl2586x+. It has hdmi 2.1 ports, but only dp 1.4.Slender wrote: β14 Jul 2025, 15:36only dp 2.1 without copper insideGrasshopper85 wrote: β14 Jul 2025, 07:58Guys please help, which fibre optics cables are you using. Hopefully show me the hdmi2.1 version, not dp1.4.
I can only find verg long length fibre optic cables, I can't find shorter ones.
No point using dp 2.1 cable on a dp 1.4 monitor. Hdmi 2.1 will have the least input lag over dp 1.4.
Sandy
No grounding. I have a custom resolution of 640*480! I suspect that all digital monitors now have image smoothing at standard resolutions, and this processing will increase input lag.
Sandy
I am using an HDMI cable that comes with the TV. I now find that the problem lies in the internal design of the monitor. Some monitors may not handle the DP and HDMI interfaces in the same way.
- Slender
so, cable not helped you? Or you mean you feel changes with it on lower resolution?
