I solved floaty mouse and input lag for myself (I really did this time around)
nickchraj
Re: I solved floaty mouse and input lag for myself (I really did this time around)
Post by nickchraj » 14 Apr 2026, 15:33
Charging 20$ with ai generated text and zero proof is insane.
mago
Post by mago » 14 Apr 2026, 17:33
have u saw less gpu memory usage by dwm.exe ?
β“ˆΠΊπ•€lŁ เ𝓒 α΅—β’ΊΠΌπ•‘Οƒο½’π€π‘β“Ž, lά𝔾 I𝐬 F𝔬ʳ𝔒𝓿ᗴ𝔯
Hyote
Post by Hyote » 15 Apr 2026, 05:26
mago wrote: ↑
14 Apr 2026, 17:33
That's a weird thing to ask. I don't know but there should be less resource usage, especially with around 80% of the dwm threads disabled.
mago
Post by mago » 15 Apr 2026, 05:50
Hyote wrote: ↑
15 Apr 2026, 05:26
mago wrote: ↑
14 Apr 2026, 17:33
why weird if dwm was bloaty its good indication
btw i also did same testing cs2 have same lower pcl and mouse feels better with this tweak
cant say im sure 100%
but there same good indications
Hyote
Post by Hyote » 15 Apr 2026, 07:27
mago wrote: ↑
15 Apr 2026, 05:50
Hyote wrote: ↑
15 Apr 2026, 05:26
mago wrote: ↑
14 Apr 2026, 17:33
This is how they are auto suspended if they are chosen on my OS.
mago
Post by mago » 15 Apr 2026, 10:20
Code: Select all
dwm.exe, 13440, 0.13, 0.33, 12.19 kB/s, 105.46 MB, 488.61 MB, 6.62 MB, Window Manager\DWM-2, Desktop Window Manager, 3,319,612,551
csrss.exe, 13252, , 0.26, , 3.3 MB, 50.62 MB, 63.33 MB, NT AUTHORITY\SYSTEM, Client Server Runtime Process, 936,114,931
after logoff
Server 2025 do better dwm.exe - 360mb - vram
win11 - DWM.exe 488.61 MB - vram
Hyote
Post by Hyote » 15 Apr 2026, 13:43
mago wrote: ↑
15 Apr 2026, 10:20
Code: Select all
after logoff
Sounds cool, I might make a build.
kimchi man
Post by kimchi man » 22 Apr 2026, 06:34
So you think the cause of the problem is Windows?
Hyote
Post by Hyote » 22 Apr 2026, 10:41
kimchi man wrote: ↑
22 Apr 2026, 06:34
No, but the difference a tweaked Windows can make is night and day. I don't deny EMI being an important factor, it just kind of doesn't matter for me anymore as my system is properly set up, so the effects of EMI are very minimal.
nickchraj
Post by nickchraj » 22 Apr 2026, 14:06
Hyote wrote: ↑
22 Apr 2026, 10:41
kimchi man wrote: ↑
22 Apr 2026, 06:34
kkkkkk sounds like you just wanna make profit off us poor input laggers
