Zowie Dyac3 + New Monitors Rumor
petight
Re: Zowie Dyac3 + New Monitors Rumor
Post by petight » 22 May 2026, 10:51
kyube wrote: ↑
18 May 2026, 07:05
I haven't seen any OSRTT data for the 750Hz models with RGB 5/10 Offset yet.
They mostly do 10-90% G2G RT (VESA standard) for reviews, which hides the weak transitions easier.
Even OSRTT hides transitions :D
I only saw g2g. But it was an improvement over existing 600hz panels so that's something at least.
24G2Z - XV252QF - AW2524HF - XV242F - AG246FK6
betonKruglosuTotchno
Post by betonKruglosuTotchno » 20 Jun 2026, 10:58
The eSports player I know just posted that Benq got him to test Dyac 3. I wonder if it's similar to Pulsar.
MSIfanboy
Post by MSIfanboy » 20 Jun 2026, 23:06
what i have noticed with zowies/monitors in general, if you bump up the brightness with black equalizer and lower the gamma, it ruins the percieved clarity, contrast ratio is a percieved clarity also, and heaps of people will not lock there fps to the refresh rate, or dont even get enough fps to match there refresh rate
DanDare
Post by DanDare » 26 Jun 2026, 07:08
My wishlist :
360hz or above
1440p
<0.5ms screen persistence
<3ms of latency.
We have plenty of monitors which do 3 out of 4 of these and none that do 4/ 4
Post by betonKruglosuTotchno » 26 Jun 2026, 13:54
DanDare wrote: ↑
26 Jun 2026, 07:08
It it technically trivial to do that at 360 Hz, you just need literally 5.5x more LED material to maintain same brightness.
(1/360) / 0.0005 = 5.55
It is not economical currently due to lack of demand.
Supermodel_Evelynn
Post by Supermodel_Evelynn » 28 Jun 2026, 21:22
Unless DYAC 3 supports VRR then it's dead on arrival.
We have Pulsar now, everything else is dead now unless it supports VRR
MSIfanboy
Post by MSIfanboy » 29 Jun 2026, 03:14
Supermodel_Evelynn wrote: ↑
28 Jun 2026, 21:22
i have asus pulsar, i went back to my zowie, locked at 300fps/custom 300hz, amazing
though i am waiting for 120hz improved ulmb2 mode for the pulsar
kyube
Post by kyube » 29 Jun 2026, 06:46
MSIfanboy wrote: ↑
29 Jun 2026, 03:14
I still don't know why they're hesitating in implementing ULMB2 properly on 240Hz & 360Hz, akin to the PG27AQN.
Ridiculously low effort implementation...
I have to address the meme in the room though.
Tell me that you don't know how backlight strobing works without telling me that you don't:
28 Jun 2026, 21:22
MSIfanboy
Post by MSIfanboy » 02 Jul 2026, 08:09
27 inch and 24.1 inch, and super expensive, i like zowie, but these comparisons they make are so bad, always super low quality aswell, the person who makes these, needs to be fired asap
Screenshot 2026-07-02 230814.png (829.87 KiB) Viewed 1358 times
radeko
Post by radeko » 02 Jul 2026, 08:28
AOC Agon Pro AGP257FT 1000hz
BOE on the panel, which also boasts a near-instantaneous 0.2ms gray-to-gray (GtG) response time via BLMB (Boe Low Motion Blur)
LG C1 55"
