I only saw g2g. But it was an improvement over existing 600hz panels so that's something at least.
Zowie Dyac3 + New Monitors Rumor
petight
Re: Zowie Dyac3 + New Monitors Rumor
24G2Z - XV252QF - AW2524HF - XV242F - AG246FK6
betonKruglosuTotchno
The eSports player I know just posted that Benq got him to test Dyac 3. I wonder if it's similar to Pulsar.
MSIfanboy
what i have noticed with zowies/monitors in general, if you bump up the brightness with black equalizer and lower the gamma, it ruins the percieved clarity, contrast ratio is a percieved clarity also, and heaps of people will not lock there fps to the refresh rate, or dont even get enough fps to match there refresh rate
DanDare
My wishlist :
360hz or above
1440p
<0.5ms screen persistence
<3ms of latency.
We have plenty of monitors which do 3 out of 4 of these and none that do 4/ 4
360hz or above
1440p
<3ms of latency.
Supermodel_Evelynn
Unless DYAC 3 supports VRR then it's dead on arrival.
We have Pulsar now, everything else is dead now unless it supports VRR
MSIfanboy
i have asus pulsar, i went back to my zowie, locked at 300fps/custom 300hz, amazingSupermodel_Evelynn wrote: ↑28 Jun 2026, 21:22Unless DYAC 3 supports VRR then it's dead on arrival.
though i am waiting for 120hz improved ulmb2 mode for the pulsar
- kyube
I still don't know why they're hesitating in implementing ULMB2 properly on 240Hz & 360Hz, akin to the PG27AQN.
Ridiculously low effort implementation...
I have to address the meme in the room though.
Tell me that you don't know how backlight strobing works without telling me that you don't:
MSIfanboy
27 inch and 24.1 inch, and super expensive, i like zowie, but these comparisons they make are so bad, always super low quality aswell, the person who makes these, needs to be fired asap
- Screenshot 2026-07-02 230814.png (829.87 KiB) Viewed 3853 times
radeko
AOC Agon Pro AGP257FT 1000hz
BOE on the panel, which also boasts a near-instantaneous 0.2ms gray-to-gray (GtG) response time via BLMB (Boe Low Motion Blur)
LG C1 55"
