AOC 24G2ZU 240Hz IPS mini review
Discorz
VIP Member
Re: AOC 24G2ZU 240Hz IPS mini review
Post by Discorz » 18 Nov 2021, 08:48
nolikeee wrote:
18 Nov 2021, 08:03
Wow that is alot of monitors you tried!
Good job with bottom two ufo pursuits. But I would recommend using longer shutter camera speed of s1/60 for 240Hz capturing. For each refresh rate shutter speed should be changed by Hz/4 rule. First ufo with MBR disabled is a bit off, not tracked accurately and it shows some small amount of double imaging because of the wrong shutter setting. I assume u used something in between s100-125. Maybe try again.
This is just an example of what I mean (VG279QM @240Hz)
Image Image
Image Image
nolikeee
Post by nolikeee » 18 Nov 2021, 09:15
Discorz wrote:
18 Nov 2021, 08:48
nolikeee wrote:
18 Nov 2021, 08:03
Image Image
Image Image
I just using iphone xs max camera :)
Zace
Post by Zace » 21 Nov 2021, 11:22
Anyone know the difference between 24g2zU and 24g2zE?
Axaion
Post by Axaion » 21 Nov 2021, 13:37
both are available in EU, im in EU market and got ZU, the difference seems to be the stand it uses... from what i can tell
lucapieroo
Post by lucapieroo » 10 Feb 2022, 11:36
How does this monitor compare to MAG251RX? Which one should I buy?
nicktator
Post by nicktator » 15 Feb 2022, 12:58
Axaion wrote:
21 Nov 2021, 13:37
Yes your right. The stand is different and the U-Version does have build in speakers.
lucapieroo
Post by lucapieroo » 16 Feb 2022, 05:09
Hey, today I got my AOC 24G2ZU: is there any kind of tests I should run to try this panel? Thank you
Kosvill
Post by Kosvill » 28 Nov 2022, 13:40
Omen x 25 comparision to 24g2zu at 10:15. Omen is much better in my opinion
dg1
Post by dg1 » 13 Mar 2023, 22:36
Can you guys help me finding out how to check this monitor's panel code? I see people doing that in some videos but there is no explanation of how to do that. I got a "24G2Z" in Brazil that says it is an IPS, now Id like to know if that is correct and what exactly is the panel model in order to decide if Im going to keep it and which set of configurations to apply, specially color related.
