DP Cables
Re: DP Cables
I have dp and I show 2.7 gbps, what does it depend on?
SeekNDstroy
Re: DP Cables
Hi, i saw this pic on internet already. But mine ended at adjustment area. No monitor tab.Nawafwabs wrote: ↑09 Sep 2022, 01:42SeekNDstroy wrote: ↑08 Sep 2022, 22:53Pardon me, im using latest gpu-z with an amd gpu with hdmi on LG 24gl600f. I dont see any monitor info(5.1gbps / 8.2gbps! ) on my gpu-z ? Is this DP cable or Nvidia specific option only? Thanks.![]()
After some search, i found that in adrenaline software, HDMI link status monitoring is disabled. Couldn't find anything to enable it. I guess for this its not showing on gpu-z.
Re: DP Cables
The new cable just arrived.
Mine still says 5.4 Gbps current & max. Not sure what I was expecting, but for $15 bucks, I'm in. Seeing if I feel any difference during gameplay anyways.
GPU: 1080Ti
Monitor: ASUS VG258QM 280Hz
GPU: 1080Ti
Re: DP Cables
1000 series need a firmware update for 1.4 speeds, if you dont, 5.4 is the expected max speeds.
Re: DP Cables
I have a 3000 series and yet the speed is limited to 5,4.
Tuhin Lavania
Re: DP Cables
I have a 3080ti and it shows 8.1 in both. ive ordered the cable, i dont have any hopes though.
