The Official *Dell Alienware AW2521H 360Hz* Owners Thread
justnvc
Re: The Official *Dell Alienware AW2521H 360Hz* Owners Thread
Oh sorry you just hold 1 + 3 and then press the power button, don't release them, and once it turns on the service menu is on the left side, sometimes it vanishes instantly but do it a couple times and it will appear for sure. Can you take a screenshot of both all of your service menus? I'd like to compare versions. Thanks!
- Discorz
- VIP Member
Thanks for the instructions.
Kyouki
I cannot seem to enter mine, what's considered 1/3 buttons? tried both combinations from up and down.
I feel stupid.
I feel stupid.
- Discorz
- VIP Member
It's function buttons, counting from top to bottom, ignoring joystick. Power button is located below on the right side.
- Power off the monitor.
- While holding buttons 1 and 3, press power button once to power on the monitor, keep holding 1 and 3 until image with factory/service menu appears on screen. Sometimes menu disappears when buttons 1 and 3 are released. In this case repeat the process.
Kyouki
Figured it out, thank you. Though couldn't find the boot option? Wouldn't mind that off.Discorz wrote: ↑10 Nov 2022, 02:27It's function buttons, counting from top to bottom, ignoring joystick. Power button is located below on the right side.
Not much in there tho. I'd like to see "disable boot logo" option to cut on boot time.
Here is mine:
Shade7
Those of you who are still using this monitor, do you install the drivers from dell for it? Or are you just using the default Microsoft Generic PnP driver?
What is the purpose of the OEM driver?
Kyouki
Only the name I believe, not much more it adds but I do it anyways to pretty it up or some monitors may require it for some games as they look into that information first.
Don't know if it does anything beyond that but I do it just because that makes me feel better.
ysenojftw
What’s the recommended setting for 360hz uncapped? Fast super fast or extreme?
Kyouki
I am using Fast according to rtings testing result:
https://www.rtings.com/monitor/reviews/ ... st-results
lecam
csgo looks better using 240Hz ULMB imo,
But when i set a profile like "ComfortView" and start the game i can't change it to any others. So i have to change profile before i start the game that enables ULMB. Am i doing something wrong?
This is awkward tbh
This is awkward tbh
