No FPS gaming possible
1000WATT
Re: No FPS gaming possible
Post by 1000WATT » 27 Jul 2025, 14:36
LaggyTyp wrote: ↑
27 Jul 2025, 11:30
ChristophSmaul1337
Make a tracert to the first node 46.223.197.252 show the result. It seems to me that the problem is between LaggyTyp and the first node. I doubt that you will have a jitter of 5ms like LaggyTyp.
This is a tracert of 2000 km 2 different providers at the same time.. And Vodafone, the intermediary that sells traffic to my country, does not cause any complaints.
ChristophSmaul1337
Post by ChristophSmaul1337 » 27 Jul 2025, 14:55
1000WATT wrote: ↑
27 Jul 2025, 14:36
tracert
tracert
Screenshot 2025-07-27 215114.png (26.21 KiB) Viewed 3269 times
1000WATT wrote: ↑
27 Jul 2025, 14:36
tracert doesn't show jitter, a repeated ping test does. Here's my result
ping
ping
Screenshot 2025-07-27 215338.png (11.81 KiB) Viewed 3269 times
High jitter might just be a simple QoS mechanism where ICMP packets are deemed unimportant in a high-load scenario, thus being delayed on purpose for other, more important traffic to come through. It might indicate something, but it's not definitive.
LaggyTyp
Post by LaggyTyp » 30 Jul 2025, 15:13
The following change has brought the biggest improvement so far, and I'm not a placebo type.
tscsyncpolicy = Enhanced
useplatformclock = No
disabledynamictick = Yes
I'd like to understand WHY?
Post by Slender » 31 Jul 2025, 01:56
LaggyTyp wrote: ↑
30 Jul 2025, 15:13
what windows ver?
LaggyTyp
Post by LaggyTyp » 31 Jul 2025, 02:04
W11 24H2 ReviOS
LaggyTyp
Post by LaggyTyp » 31 Jul 2025, 07:15
It works!
It works with my platform. With my motherboard. With my CPU.
It doesn't work with a friend (AMD 9800X3D).
LaggyTyp
Post by LaggyTyp » 31 Jul 2025, 14:19
Someone messaged me and asked me exactly what settings I had.
1.) All network card options (Device Manager) disabled
a) Interrupt Moderation = On
b) Interrupt Moderation Rate = Off
d) Network card Transmit Buffer (Device Manager) = 1024
e) Network card Receive Buffer (Device Manager) = 2048
2.) REG: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile
a) NetworkThrottlingIndex = 70 (Decimal)
b) SystemResponsiveness = 0 (Decimal)
3.) CMD@Admin: netsh interface tcp set global rsc=disabled
4.) CMD@Admin: netsh interface udo set global uro=disabled
5.) CMD@Admin: netsh interface udo set global uso=disabled
6.) CMD@Admin: bcdedit /set tscsyncpolicy enhanced
7.) CMD@Admin: bcdedit /set useplatformclock No
8.) CMD@Admin: bcdedit /set disabledynamictick Yes
Hyote
Post by Hyote » 31 Jul 2025, 15:16
LaggyTyp wrote: ↑
31 Jul 2025, 02:04
W11 24H2 ReviOS
This will never fail to make me laugh. A version of Windows benchmarked to be worse than stock in some games is actually the solution to all the problems.
LaggyTyp
Post by LaggyTyp » 31 Jul 2025, 15:20
No.
It ran poorly with Windows 11 24H2 (Hitreg)
It ran poorly with Windows 11 24H2 + ReviOS (Hitreg)
Only with the changes did it run normally again.
PS: FPS are and never have been a problem.
Hyote
Post by Hyote » 31 Jul 2025, 15:52
LaggyTyp wrote: ↑
31 Jul 2025, 15:20
No.
These bcdedits are the best for me on my own fully updated version of 24H2 with HPET disabled in BIOS.
BCDEDIT /set nx AlwaysOff >NUL 2>&1
BCDEDIT /set ems No >NUL 2>&1
BCDEDIT /set bootems No >NUL 2>&1
BCDEDIT /set integrityservices disable >NUL 2>&1
BCDEDIT /set tpmbootentropy ForceDisable >NUL 2>&1
BCDEDIT /set bootmenupolicy Legacy >NUL 2>&1
BCDEDIT /set debug No >NUL 2>&1
BCDEDIT /set hypervisorlaunchtype Off >NUL 2>&1
BCDEDIT /set disableelamdrivers Yes >NUL 2>&1
BCDEDIT /set isolatedcontext No >NUL 2>&1
BCDEDIT /set allowedinmemorysettings 0x0 >NUL 2>&1
BCDEDIT /set vm No >NUL 2>&1
BCDEDIT /set vsmlaunchtype Off >NUL 2>&1
BCDEDIT /set x2apicpolicy Disable >NUL 2>&1
BCDEDIT /set configaccesspolicy Default >NUL 2>&1
BCDEDIT /set MSI Default >NUL 2>&1
BCDEDIT /set usephysicaldestination No >NUL 2>&1
BCDEDIT /set usefirmwarepcisettings No >NUL 2>&1
BCDEDIT /set tscsyncpolicy Legacy >NUL 2>&1
BCDEDIT /deletevalue useplatformclock >NUL 2>&1
BCDEDIT /set disabledynamictick yes >NUL 2>&1
BCDEDIT /set useplatformtick No >NUL 2>&1
BCDEDIT /set useplatformclock False >NUL 2>&1
BCDEDIT /set uselegacyapicmode Yes >NUL 2>&1
BCDEDIT /set sos no >NUL 2>&1
BCDEDIT /set pae ForceDisable >NUL 2>&1
BCDEDIT /set maxproc No >NUL 2>&1
BCDEDIT /set restrictapicluster 0 >NUL 2>&1
