Definitely go with G-SYNC Pulsar! That is literally the best of the best, today, tomorrow, and always.daviddave1 wrote: ↑03 Nov 2026, 16:30Hey thx for replying! I play Apex Legends at an constant 300 fps. Would u play it on ULMB2 mode or PULSAR?
Even if you maintain a constant 300 FPS, Apex can get really chaotic in big fights, and your frames might drop just a little bit. With ULMB 2, you have to turn off G-SYNC, so any small drop will cause screen tearing.
Pulsar is basically the evolution of ULMB 2 (or whatever other competing strobing tech), giving you incredible motion clarity that's super close to it, but with G-SYNC turned on. You don't have to choose between motion blur and screen tearing. It's a no-brainer! That makes Pulsar a total revolution.
