FPS drops when moving mouse or keyboard
SKILLEN
Post by SKILLEN » 10 Jan 2023, 17:13
When i move mouse or press keyboard the fps drops from 900 to 500 or even if i lock fps to 400 it drops to 330-350.
i5 12400f (hyper threading on/off)
gtx 1080ti (tried few drivers)
G403 Hero (125-1000hz doesnt matter)
Disable all power saving
No discord,no overlays
updated drivers
Its probably game fault ,but can someone check if you have same problem.
SKILLEN
Re: FPS drops when moving mouse or keyboard
Post by SKILLEN » 10 Jan 2023, 22:28
Only with reinstall windows i was able to fix this.
imprecise
Post by imprecise » 14 Jan 2023, 14:37
Can you share a screenshot of your RAM configuration in HWINFO?
Example:
download/file.php?id=3141
Unixko
Post by Unixko » 14 Jan 2023, 15:38
SKILLEN wrote:
10 Jan 2023, 17:13
updated drivers
are you trolling or ??? you look at a 2 different places obviously a place where is more to show has less fps and where is nothing behind has more fps go to kz server and you will have 1500 fps when you look up or down you have more fps obviously xD
SKILLEN
Post by SKILLEN » 14 Jan 2023, 21:48
From previous posts I know you r not very smart,but anyway I will explain to you.The place is the same and how I said when I move mouse fps drops so I moved mouse up/down to have time to take screenshot,go check on this map on the same spot If you watch wall or up/down fps will be the same.i can't believe I have to explain this to members on this forum.
SKILLEN
Post by SKILLEN » 14 Jan 2023, 21:53
imprecise wrote:
14 Jan 2023, 14:37
Example:
Hello,I reinstalled windows and its fixed,
