Hi! After Mark shared his guide over at eve.community, I decided to attempt to capture the performance of the Eve Spectrum ES07D03 with the BlurBuster's tuned strobing settings and without it to show the difference. I'd really appreciate it if I could get some feedback on these attempts to see if they're suitable to share or how I can improve and attempt it again.
Here's the video I recorded with my camera setup on a slider at the level of the screen. In this one, long pulse width strobing is enabled with response time overdrive set to "Normal" and low-latency mode turned on. I was able to get a few frames from this one that looked very clear and I believe had accurate tracking.
youtu be/64y-raJhIJM
For this next one, strobing is turned off, response time overdrive is set to "Normal", and low-latency mode is on. I wasn't able to get any individual frames from this one, as the video looks very blurry, no matter how I adjusted the camera.
youtu be/5bPnBY49jD0
Here are the images I was able to get from the first (strobing) video.
4K 144Hz Pursuit, Without Large-VT Tweaks
4K 100Hz Pursuit, Without Large-VT Tweaks
[EDIT: 4K 100Hz added below]
Looking for test performance feedback | Pursuit camera ghosting test on Eve Spectrum ES07D03
Javild
Javild
Re: Looking for test performance feedback | Pursuit camera ghosting test on Eve Spectrum ES07D03
Sorry, I wasn't able to upload the videos directly because of their size, and I'm not able to embed any external videos in the post.
Hello Javid,
Only seeing thigs post now. Thanks for posting these!
These are very good first-attempt pursuits!
Can you please post YouTube links by deleting the https, deleting the www, and deleting all periods, such as "youtu be/asdfasdfasd"? New forum members (up to about a few posts) have link posting blocked until out of new forum member status.
You will want to improve the defocussing siutuation (camera focus) and non-display-blurring situation (camera vibrations), as follows:
- Discorz
- VIP Member
Good attempt!
Iso and shutter speed look good. Maybe improve focus and lower the camera height or angle to align all 3 cyan rows to middle. You can also do a fullscreen crosstalk test.
Javild's video links from first comment:
1. https://youtu.be/64y-raJhIJM
2. https://youtu.be/5bPnBY49jD0
I'd recommend to add basic monitor settings to yt video description
Which one is 100Hz tho?
