XL2566X+, 400HZ DYAC 2
- PapaJuan
https://www.reddit.com/r/Zowie/s/pB7l5v4QWR
ParkGGoki posted this on the Zowie reddit.
I found the original link: https://m.dcinside.com/board/mnt/742393
- RDT_20240530_1332183754363888878277745.jpg (618.45 KiB) Viewed 36556 times
- RDT_20240530_1330426289229203690849001.jpg (5.08 KiB) Viewed 36556 times
Supermodel_Evelynn
Re: XL2566X+, 400HZ DYAC 2
Nasty ugly bezels and TN panel 1080p YUCK
- PapaJuan
Looks like leaks were true again.
MSIfanboy
need a 1440p 24.5 inch atleast 240hz zowie, to consider buying a TN ever again
- kyube
Video review: https://www.bilibili.com/video/BV1hrpMe4EvL/ (contains color-related, contrast, brightness, pwm test, no ufo and g2g)
Seems to be using WLED backlight? Service menu cannot be accessed with the usual way (like on the XL2566K)
(Discrete) rolling scan backlight strobing (DyAc 2) TestUFO ghosting pursuit photographs:
Notes: 1920px/s was used
DyAc2 Premium was used across all of these.
Some have incorrect shutter speed set (was an accident by the end-user), therefore the stair pattern is cut in the middle.
(Discrete) rolling scan backlight strobing (DyAc 2) crosstalk pursuit photographs:
Panel seems to be this: https://www.panelook.com/M241HTN01.6_AU ... 65686.html (new one, the XL2566K used M250HTN01.J)
Unstrobed (VRR off) / Sample & Hold @ 400hz (1440 px/s)
Here's how the monitor looks like in SoftMCCS
Thanks for posting a video review!
- Discorz
- VIP Member
There is some front leaning crosstalk at top of the screen. I wonder why that is. Normally new DyAc 2 doesn't do that.
Interesting how people don't know to reduce overdrive for lower refresh rates. AMA 17 is a bit too much for 540Hz, let alone 240Hz and below.
- kyube
Here's a screenshot of the blurbusters utility with the new DyAc2 monitors.
Supposedly, the Persistence option works down to 10 (default was 16) & Crosstalk Area doesn't change anything (or changes it very minimally, according to the person who submitted the screenshot)
Hope this is of any use.
Watchdog
Is motion clarity on XL2566X+ good? I'm also looking for OLED 24" with at least 400hz refresh rate.
Anonymous703819
Same with XL2546Xkyube wrote: ↑28 Sep 2024, 15:25Here's a screenshot of the blurbusters utility with the new DyAc2 monitors.
