Would rlly appreciate some help with getting the right flip model on my game
Panychkaaa
Re: Would rlly appreciate some help with getting the right flip model on my game
Post by Panychkaaa » 10 Mar 2025, 11:14
JimCarry wrote: ↑
02 Mar 2025, 11:19
Panychkaaa wrote: ↑
26 Feb 2025, 10:25
HKEY_CURRENT_USER\System\GameConfigStore\Children\ -> Search (VALORANT-Win64-Shipping.exe) -> Flags -> 211
i dont have these keys i delete them long time ago,any other way? i have mpo disabled and in gameconfigstore everything is on 0.
Microsoft store > Install Xbox > Install Game bar > Run Game > Win + G > Remember game ;)
JimCarry
Post by JimCarry » 10 Mar 2025, 11:33
Panychkaaa wrote: ↑
10 Mar 2025, 11:14
JimCarry wrote: ↑
02 Mar 2025, 11:19
Panychkaaa wrote: ↑
26 Feb 2025, 10:25
i disabled game bar via script.
Panychkaaa
Post by Panychkaaa » 11 Mar 2025, 09:17
JimCarry wrote: ↑
10 Mar 2025, 11:33
Panychkaaa wrote: ↑
10 Mar 2025, 11:14
JimCarry wrote: ↑
02 Mar 2025, 11:19
Panychkaaa wrote: ↑
26 Feb 2025, 10:25
:cry:
mocha__
Post by mocha__ » 11 Mar 2025, 18:56
did anyone figure out how to get Hardware Compose: Independent Flip?
Post by RealNC » 12 Mar 2025, 02:47
mocha__ wrote: ↑
11 Mar 2025, 18:56
It happens when MPOs are active. MPOs are disabled when running in a secondary display, or when DSR/DLDSR is used on Nvidia, or on some Windows versions when the output color depth is higher than 8-bit. When MPOs aren't used, you get "Hardware: Independent Flip".
mocha__
Post by mocha__ » 12 Mar 2025, 13:14
RealNC wrote: ↑
12 Mar 2025, 02:47
mocha__ wrote: ↑
11 Mar 2025, 18:56
ok so i have 2 active displays at all times, ive tried with mpo disable and enabled and no matter what in CS2 at least, i get Hardware: Independent Flip. i havent been able to get the Hardware Compose: Independent Flip. unless CS2 isnt able to use that flip mode? im not sure anymore as ive tried all different ways. fullscreen borderless is the same, using flags of 211 is legacy flip obviously. ive tried hags on and off just to see but still cant get the hardware composed part
JimCarry
Post by JimCarry » 12 Mar 2025, 13:37
i think i will not disable mpo,on my pc lowers fps.
andrelip
Post by andrelip » 13 Mar 2025, 10:07
You can check if it's enabled or not using dxdiag and then saving the report into a text file. Search for MPO; if it shows 1 with a short block code after that, it's because it's disabled. If multi-panel is 4 and has a lot of lines after that, then it's enabled.
Mine is disabled by default (did no tweak - I believe because I have triple screens) but it activates when I use restart-64 from CRU.
With that disabled, my FLM (Frame Latency Meter ) shows 390fps (my refresh rate) in CS2 when windowed/borderless and unlocked when it's enabled. The game reports unlimited fps in both cases, but FLM tests for actual changes in image. So it's clearly using vsync in the compositor as the changes matches my refreshrate.
CS2 does not seems to have a real FSE and FLM doesn´t work with the "Full Screen" option of the game. I recommend you to ensure it's always on before playing.
awuhdlaui
Post by awuhdlaui » 17 Mar 2025, 00:03
If anyone is looking at this in the future because they cant get multi plane overlay to work, you need a graphics card which supports it. I own a 1080ti and can't use hardware composed : independent flip because it doesn't support multi plane overlay. Now I have to figure out if legacy flip or independent flip are better.
JimCarry
Post by JimCarry » 17 Mar 2025, 10:11
awuhdlaui wrote: ↑
17 Mar 2025, 00:03
Thanks for sharing but how do i know if my vc suports it ?
