... Go on, troll me guys, but I'm telling the truth - those things are 100% reproduceable. What I noticed relieves the lag as well is touching PC case screws - it's like some static buildup or something discharges in me and it feels perfect for few seconds. I feel like I'm very close to realizing what's the issue. Can it be my PC case?
Input lag disappears for ~30 seconds when plug OR unplug any USB.
Re: Input lag disappears for ~30 seconds when plug OR unplug any USB.
Here's how the ChatGPT explains it:
I tried attaching the PC case to the grounding on the extension cord with a copper wire, as it suggested, it seems like it's at lest 30-40% better, but it started off with a 100% for half a minute and it felt so amazing, like noone could ever win a duel against me. The grounding on my apartment is fine, I checked it with multimeter.
https://www.youtube.com/watch?v=-1zaM_1aSqQDMNCS wrote: ↑25 Apr 2025, 19:14... Go on, troll me guys, but I'm telling the truth - those things are 100% reproduceable. What I noticed relieves the lag as well is touching PC case screws - it's like some static buildup or something discharges in me and it feels perfect for few seconds. I feel like I'm very close to realizing what's the issue. Can it be my PC case?
did you plug every cable all the way not only the pc cable but the monitor and all others?DMNCS wrote: ↑25 Apr 2025, 19:25Here's how the ChatGPT explains it:
I did, yesJimCarry wrote: ↑25 Apr 2025, 19:38did you plug every cable all the way not only the pc cable but the monitor and all others?DMNCS wrote: ↑25 Apr 2025, 19:25Here's how the ChatGPT explains it:
I have another huge clue - changing angle of monitor power supply cable relieves lag for ~30 seconds. Any ideas?
In case anyone follows this thread in the future, here's an update:
An electrician came to my apartment an noticed that there's a TN-C system in the building, so there is ultimately no real grounding, which completely explains the issues I'm having. I'm located in Serbia and there is another thread to further back this point up - viewtopic.php?t=10543
Neutral is always grounded at some point in TN-C. It is not as good grounding a separate wire, but still it should be bonded at sockets at least in bathroom and kitchen for safety purposes.
That doesn't explain why it would work and then stop working, unless this kind of installation does not handle things good enough anymore.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / Dell Alienware AW3225QF / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor (source being removed)
So the problem isn't necessarily the TN-C? I mean - TN-C systems are not the root cause of the issue we have, there are other contributing factors is what you're trying to say? The only thing I haven't tried yet (after trying almost everything and replacing the entire PC) is getting another PC case, this one was pretty cheap and it's possible that the case itself is on floating ground, but I doubt that honestly.dervu wrote: ↑03 May 2025, 15:52Neutral is always grounded at some point in TN-C. It is not as good grounding a separate wire, but still it should be bonded at sockets at least in bathroom and kitchen for safety purposes.
I see that you are pretty active in this forum and very well informed, if you have any suggestions for me, I'd be more than happy to read them.
viewtopic.php?f=24&t=14113&p=110973#p110973DMNCS wrote: ↑25 Apr 2025, 19:14... Go on, troll me guys, but I'm telling the truth - those things are 100% reproduceable. What I noticed relieves the lag as well is touching PC case screws - it's like some static buildup or something discharges in me and it feels perfect for few seconds. I feel like I'm very close to realizing what's the issue. Can it be my PC case?
Look at one of my replies, I found the same temporary "fix" which is reproducable at all times. The only thing that is persistent is that at night, everything looks way smoother and the shots are landing, essentially like 2 different people playing.
