anyway to deactivate usb interrupt moderation?
Re: anyway to deactivate usb interrupt moderation?
Post by Slender » 13 Sep 2025, 13:41
petergase wrote: ↑
13 Sep 2025, 13:38
Slender wrote: ↑
12 Sep 2025, 23:49
petergase wrote: ↑
12 Sep 2025, 19:10
Slender wrote: ↑
11 Sep 2025, 00:20
amd cpu usb 2.0 > amd cpu usb 3.0 > mcs9990 > GL 2.0 > intel usb controller
for intel yes, it make sence
ok I bought one and testing right now
msi mode on or off?
and have u installed a driver?
only mouse or also keyboard and audio?
Is that light on your device also permanently red? I connected the power cable.
there is only non-msi mode.
there is 8 separate controller inside (4 - 1.1, 4 - 2.0), you can connect keyboard and mice.
i dont use power cable for it.
thats the one I have usb 2.0
and you havent installed any additional drivers?
yes, but i think it work better with csm mode + legacy io latency enabled (scewin setting)
petergase
Post by petergase » 13 Sep 2025, 13:42
Slender wrote: ↑
13 Sep 2025, 13:41
petergase wrote: ↑
13 Sep 2025, 13:38
Slender wrote: ↑
12 Sep 2025, 23:49
petergase wrote: ↑
12 Sep 2025, 19:10
msi mode on or off?
i will try
and how to change from ohci mode to ehci?
my mouse is connected to ohci
somehow theres a msi option or does this not work?
Post by Slender » 14 Sep 2025, 00:39
petergase wrote: ↑
13 Sep 2025, 13:42
Slender wrote: ↑
13 Sep 2025, 13:41
petergase wrote: ↑
13 Sep 2025, 13:38
Slender wrote: ↑
12 Sep 2025, 23:49
i will try
you not need that
that is old like controller
petergase
Post by petergase » 19 Sep 2025, 16:59
Slender wrote: ↑
14 Sep 2025, 00:39
petergase wrote: ↑
13 Sep 2025, 13:42
Slender wrote: ↑
13 Sep 2025, 13:41
petergase wrote: ↑
13 Sep 2025, 13:38
i will try
you not need that
Okay, I've been testing it for a week now, and you can definitely notice a difference compared to the xhci Intel USB controller, but it's still not quite the same as when I run imod on the Intel USB controller. Maybe it's because my mouse has 4k, but it's better than with the Intel USB controller without tweaking.
And I think I've found an RWEverything alternative that still works with Core Isolation. It works, but the program looks like malware
F1zus
Post by F1zus » 28 Feb 2026, 18:24
petergase wrote: ↑
19 Sep 2025, 16:59
What is an alternative program to RW for disabling interrupt moderation?
amorou
Post by amorou » 01 Mar 2026, 05:20
Slender wrote: ↑
11 Sep 2025, 00:20
F1zus wrote: ↑
10 Sep 2025, 18:36
Slender wrote: ↑
10 Sep 2025, 09:17
yes, mcs9990 dont have it
How does the mouse feel compared to a direct connection to the CPU USB (AMD)? Does it make sense to buy a separate USB card?
Wow you put intel lower than amd usb 3.0 ?
Does this applies to old gens ( 2012-2017 ) aswell ?
Post by Slender » 01 Mar 2026, 05:35
amorou wrote: ↑
01 Mar 2026, 05:20
Slender wrote: ↑
11 Sep 2025, 00:20
F1zus wrote: ↑
10 Sep 2025, 18:36
Slender wrote: ↑
10 Sep 2025, 09:17
it applies only for new gen crap intel.
z390 and z490 last good intel with perfect usb polling rate (delta 999.9-1000.1)
