Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Post
by Slender » 13 Sep 2025, 13:41
petergase wrote: ↑13 Sep 2025, 13:38
Slender wrote: ↑12 Sep 2025, 23:49
petergase wrote: ↑12 Sep 2025, 19:10
Slender wrote: ↑11 Sep 2025, 00:20
amd cpu usb 2.0 > amd cpu usb 3.0 > mcs9990 > GL 2.0 > intel usb controller
for intel yes, it make sence
ok I bought one and testing right now
msi mode on or off?
and have u installed a driver?
only mouse or also keyboard and audio?
Is that light on your device also permanently red? I connected the power cable.
there is only non-msi mode.
there is 8 separate controller inside (4 - 1.1, 4 - 2.0), you can connect keyboard and mice.
i dont use power cable for it.
thats the one I have usb 2.0
and you havent installed any additional drivers?
yes, but i think it work better with csm mode + legacy io latency enabled (scewin setting)
petergase
Post
by petergase » 13 Sep 2025, 13:42
Slender wrote: ↑13 Sep 2025, 13:41
msi mode on or off?
i will try
and how to change from ohci mode to ehci?
my mouse is connected to ohci
somehow theres a msi option or does this not work?
- usb.png (17.64 KiB) Viewed 9567 times
- ohci.png (14.42 KiB) Viewed 9568 times
Post
by Slender » 14 Sep 2025, 00:39
petergase wrote: ↑13 Sep 2025, 13:42
i will try
you not need that
that is old like controller
petergase
Post
by petergase » 19 Sep 2025, 16:59
Slender wrote: ↑14 Sep 2025, 00:39
i will try
you not need that
Okay, I've been testing it for a week now, and you can definitely notice a difference compared to the xhci Intel USB controller, but it's still not quite the same as when I run imod on the Intel USB controller. Maybe it's because my mouse has 4k, but it's better than with the Intel USB controller without tweaking.
And I think I've found an RWEverything alternative that still works with Core Isolation. It works, but the program looks like malware
F1zus
Post
by F1zus » 28 Feb 2026, 18:24
petergase wrote: ↑19 Sep 2025, 16:59
What is an alternative program to RW for disabling interrupt moderation?
amorou
Post
by amorou » 01 Mar 2026, 05:20
F1zus wrote: ↑10 Sep 2025, 18:36
Slender wrote: ↑10 Sep 2025, 09:17
yes, mcs9990 dont have it
How does the mouse feel compared to a direct connection to the CPU USB (AMD)? Does it make sense to buy a separate USB card?
Wow you put intel lower than amd usb 3.0 ?
Does this applies to old gens ( 2012-2017 ) aswell ?
Post
by Slender » 01 Mar 2026, 05:35
amorou wrote: ↑01 Mar 2026, 05:20
it applies only for new gen crap intel.
z390 and z490 last good intel with perfect usb polling rate (delta 999.9-1000.1)
