solved Floaty Mouse- Reproducable fix-
themagic
Re: solved Floaty Mouse- Reproducable fix-
Post by themagic » 26 Sep 2025, 17:27
Completely bullshit...dont listen to this shit...
kadirg
Post by kadirg » 26 Sep 2025, 17:42
themagic wrote:
26 Sep 2025, 17:27
Maybe it works for someone, easy to test.
jeffeh12133
Post by jeffeh12133 » 28 Sep 2025, 04:09
could it end up being just the fact that it's a new bios and it's just like the other settings where you change it and it works for a little bit?
jeffeh12133
Post by jeffeh12133 » 28 Sep 2025, 04:31
since you mentioned mouse initialization, could it be just "driver-ranking issues" during mouse installation like this below thread is mentioning or do you think it's entirely something else?
viewtopic.php?f=10&t=9977
ablemor
Post by ablemor » 28 Sep 2025, 06:12
i tried linux, and it was floaty, so its not driver issue
jeffeh12133
Post by jeffeh12133 » 30 Sep 2025, 00:53
ablemor wrote:
28 Sep 2025, 06:12
did you try his fix? basically to reinstall the same bios version and try different mouse or what? how could you know if your mouse is "infected"?
themagic
Post by themagic » 30 Sep 2025, 05:03
jeffeh12133 wrote:
30 Sep 2025, 00:53
ablemor wrote:
28 Sep 2025, 06:12
mouse infected :lol: same like elctricity infected theory ? :lol:
what next ? earphones/headsets are infected ?
and what about keyboards ? are they or can be infected too ?
but most important and interesting what with touchpads ? infected ? you know there exist keyboards with touchpad ? :o
edit:
guys i find better fix and not even a fixed mouse needed to buy or search for lol:
instead of update bios with your new "fixed mouse"...just put a "fixed usb gamepad" (you can even use the ones from your console) and then update bios. should work too or ?
after then just play some games which good for gamepad (example rocket league, fifa..) only and feel the difference haha...
dervu
Post by dervu » 30 Sep 2025, 05:49
I heard this infected theory so many times yet no one dares to send such mouse to anyone to review/check what is wrong with it.
jeffeh12133
Post by jeffeh12133 » 05 Oct 2025, 03:13
has anyone else tried this "fix" apart from the couple who posted earlier? considering trying this. just basically reinstall the same bios + use new mouse i guess? is it still giving you a smooth feeling OP?
ablemor
Post by ablemor » 05 Oct 2025, 17:50
i found better fix
