Acer 390Hz monitor - XV252QF
ne0x
Post by ne0x » 30 Oct 2021, 07:09
lyrill wrote:
30 Oct 2021, 00:13
woodyfly wrote:
29 Oct 2021, 09:43
How is the lower end of the brightness? I hate bright screen and many panels even when I turn brightness to 0 its still bright af
max os hdr brightness and foundation s01e07 half the screen is pitch black in the Invictus scene, with an open window
Coming from a TN panel, the acer seems pretty DIM when the oc settings are on.
milojr21
Post by milojr21 » 30 Oct 2021, 18:06
lmaooo HP X24c 23.6" 16:9 Curved 144 Hz FreeSync VA Gaming Monitor is winning on votes for rtings. surely another vote manipulation scandal going on, right?
lyrill
Post by lyrill » 30 Oct 2021, 19:06
ne0x wrote:
30 Oct 2021, 07:09
lyrill wrote:
30 Oct 2021, 00:13
woodyfly wrote:
29 Oct 2021, 09:43
again, depends on what brightness setting you are used to, got nothing to do with tn ips debate. but no it's not your premium hdr tv type
the foundation hdr are also way out of the league of most stuff, 2k+ nits max on almost all episodes. Dune is like not even 1k
Discorz
VIP Member
Post by Discorz » 31 Oct 2021, 03:07
milojr21 wrote:
30 Oct 2021, 18:06
Probably.
Kinda obvious. Specs and how fast it got up gave it away not the vote number this time.
lyrill
Post by lyrill » 31 Oct 2021, 05:40
Discorz wrote:
31 Oct 2021, 03:07
milojr21 wrote:
30 Oct 2021, 18:06
Probably.
1080p 144hz........? what is this 2014?
Discorz
VIP Member
Post by Discorz » 31 Oct 2021, 06:54
lyrill wrote:
31 Oct 2021, 05:40
The funniest thing is its VA panel.
paddyhhh
Post by paddyhhh » 31 Oct 2021, 07:48
I really have problems in cs go to spot enemies compared to XL2540. Models do not stand out from backround somehow.
Everything so dark and colorless. Maybe the Zowie was the other extreme and I need to adapt?
Playing/aiming feels really good and I would like to keep the acer.
Can someone share settings for competetive cs go only?
Thanks
actual settings:
colors: warm
gamma 2.2
max brightness on+increased in driver
OD normal
OC on
VRB off
Blackboost on
Saturation increased in driver
planart
Post by planart » 31 Oct 2021, 08:24
milojr21 wrote:
30 Oct 2021, 18:06
What's interesting about this monitor? Seems very odd. With 200€ msrp it's not even very interesting as a value proposition. 24" 1080P VA 144Hz 4ms.
milojr21
Post by milojr21 » 31 Oct 2021, 17:36
planart wrote:
31 Oct 2021, 08:24
milojr21 wrote:
30 Oct 2021, 18:06
someone is just manipulating votes to their crappy monitor they want reviewed, rtings voting system is very easy to mess with apparently
michaelcycle00
Post by michaelcycle00 » 31 Oct 2021, 20:15
paddyhhh wrote:
31 Oct 2021, 07:48
Thanks
actual settings:
colors: warm
gamma 2.2
OD normal
OC on
VRB off
Blackboost on
Is there any reason you have VRB off? It's pretty much the biggest selling point of this monitor (aside from the price) and the latency hit is like 0.8ms so it's basically imperceptible. It's what makes up for not having tight-knit response times.
