Coming from a TN panel, the acer seems pretty DIM when the oc settings are on.
Acer 390Hz monitor - XV252QF
lmaooo HP X24c 23.6" 16:9 Curved 144 Hz FreeSync VA Gaming Monitor is winning on votes for rtings. surely another vote manipulation scandal going on, right?
again, depends on what brightness setting you are used to, got nothing to do with tn ips debate. but no it's not your premium hdr tv type
the foundation hdr are also way out of the league of most stuff, 2k+ nits max on almost all episodes. Dune is like not even 1k
Probably.
Kinda obvious. Specs and how fast it got up gave it away not the vote number this time.
The funniest thing is its VA panel.
I really have problems in cs go to spot enemies compared to XL2540. Models do not stand out from backround somehow.
Everything so dark and colorless. Maybe the Zowie was the other extreme and I need to adapt?
Playing/aiming feels really good and I would like to keep the acer.
Can someone share settings for competetive cs go only?
Thanks
actual settings:
colors: warm
gamma 2.2
max brightness on+increased in driver
OD normal
OC on
VRB off
Blackboost on
Saturation increased in driver
Thanks
actual settings:
colors: warm
gamma 2.2
OD normal
OC on
VRB off
Blackboost on
What's interesting about this monitor? Seems very odd. With 200€ msrp it's not even very interesting as a value proposition. 24" 1080P VA 144Hz 4ms.
someone is just manipulating votes to their crappy monitor they want reviewed, rtings voting system is very easy to mess with apparently
Is there any reason you have VRB off? It's pretty much the biggest selling point of this monitor (aside from the price) and the latency hit is like 0.8ms so it's basically imperceptible. It's what makes up for not having tight-knit response times.paddyhhh wrote: ↑31 Oct 2021, 07:48I really have problems in cs go to spot enemies compared to XL2540. Models do not stand out from backround somehow.
Thanks
actual settings:
colors: warm
gamma 2.2
OD normal
OC on
VRB off
Blackboost on
