This is so ridiculous that idk. Im write to nvidias supp, they cant even say that i have a problem or what they will do with this, just send me to msi support, in msi's support they say we aware nvidia and u will get the pulse width option for 60 hz ulmb on msi 272qrf x36 in the next update.brownvim wrote: ↑28 Apr 2026, 04:31The 1.1.6 firmware update is currently available for AOC AGON PRO AG276QSG2 and MSI MPG 272QRF X36 models.BLooDS_inc wrote: ↑20 Apr 2026, 06:56How about a pulse width setting on the MSI version of pulsar monitor? Now it's just unusable cause u can't change the pulse width of 60hz ulmb mode and standard mode cause massive flickering, why only MSI 272qrf x36 is still have the worst firmware version between 4 monitors?
https://gsync-update.nvidia.com/
1.1.6:
Improved G-SYNC Pulsar operation for 100 – 180 FPS range.
Fixed monitor white-point value in EDID to D65 white-point value.
Fixed input auto-switch issue.
Fixed cable detection issue affecting input switching when using a DP80 cable.
Fixed occasional frame skip issue when second input is active.
https://nvidia.custhelp.com/app/answers ... 1.4-update
See if a pulse width setting got added? Doesn't seem like it from the above list.
And now im update the monitor to 1.1.6 and get nothing, WOW, im just give up, idk what i need to do for freaking even aware of this problem, they just threw up all the msi pulsar monitor users for nothing cause they dont want do their job properly
