Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
ahead
Post
by ahead » 18 Sep 2023, 19:52
sndhck wrote: ↑18 Sep 2023, 01:16
My thoughts were why not try to connect headphones through external power and through
an optical connector S/PDIF which is less prone to interference, and finally set the volume to 100 in windows, and adjust it with the DAC
https://en.wikipedia.org/wiki/S/PDIF
The receiver does not control the data rate.
That means it doesn't matter what DAC you use; this will change nothing in PC performance.
KingAzar
Post
by KingAzar » 19 Sep 2023, 02:20
ahead wrote: ↑18 Sep 2023, 19:52
so you mean he is experiencing mostly placebo effect?
imprecise
Post
by imprecise » 20 Sep 2023, 20:23
Another source of this audio lag can be found in Windows settings:
- windowsaudio.png (211.29 KiB) Viewed 2748 times
